Johnnymac2k6
- Oct 5, 2016
- 913
- 520
- Location
- Ohio
- 2007 Ram 1500
- 5.7 Hemi
Title says it all. While driving, and going over large bumps (fairly rough RR tracks) The truck will die...but then start right back up in neutral while rolling.
I have researched the issue and most similar occurrences appear to have engine codes, or the electrical system / throttle body fault light. This produces no lights, and the truck has continued to start/drive normal after restarting.
Has only happened twice, and i believe both were at idle. Today for sure i lifted because i figured the tracks were rough, rolled over at probably 50. they were in fact pretty bad...and truck died.
time before that, i was rolling to a stop in my driveway and was coasting to the side into a bumpy area. probably only 15 mph, but pretty bumpy. died, then started and drove as normal.
I found one alleged TSB where airbag sensors would cause this as to not deploy the airbags.
All other threads i have found result in multiple people saying to check battery terminals, and grounds, and then no other real resolution surfaces. Truck looks new in the engine bay...large grounds are in good shape and no corrosion.
2007 1500 with a hemi.
thanks for any insight anyone that has experienced and solved this can be.
