Id recommend ordering butyl rubber if you have any plans on opening them again down the road
I used Black RV Silicone to seal it back up, but like said above "JB Weld" Will fix your clips.
Little hint, before you seal it back up. Heat up your plastic to the point where it is flexible and remold ALL your channels. This way your housing and lens make a tight fit together.
I've done two sets so far, (Car & Truck) and no moisture in them yet. So fingers crossed
Looking forward to see your final product! Props your doing it yourself
I heated the butyl till it was pretty soft, but evidently I don’t have clamps capable of squeezing the headlight tight enough. They seal up but I’m able to pull them apart pretty easy. Picked up a tube of black silicone and I’ll try this. I wish I would have practiced this with some cheap lights before going crazy on mine!
I used a few pairs of vice grips as my clamps also werent strong enough, but i agree if you are 110% positive you be reopening them black rtv silicone is easier, but it can get messy so you have to be very careful
I’ve tired with the butyl and I can’t get it to seal, I heated and then clamped it together. A few hours later the lights aren’t sealed tight and I’m able to pull them apart fairly easy. It may be because of the lack of clips and not so perefct seal I made when opening for the 2nd time.... I’m thinking of using the black silicone stuff to seal it up for good, and hoping to never have to open again.
