Terry Gideon
It is the 2001, 6 cyl. WS and the problem is it will not start without a jump. The battery is fully charged and extremely good as verified by autozone, all connections are clean and tight, have tested starter relay fuse and it is good. Now when I turn the key on, it has power try to start and nothing: nada, zero, zilch.....no sounds or anything, will not even hear the starter click. Put jumper on it, it'll start right up, it will, while idling/driving, light up on the dash "Check Gauges" and after a few will go away then return again a few later. Turn power off, gotta jump it again to start. Any ideas?
