Starting Issues , engine not cranking
boatman3162
Staten island
Good afternoon everyone ! Having intermittent starting problems with my 08 Ram with the 4.7 - Takes multiple times to start with the key fob or manually in the ignition switch - I have the max care warranty , so the dealer went ahead and changed the starter - next day same issue - battery is relatively new , so are the batteries in the key fobs - there is an aftermarket market and stereo that were installed several years ago but hasn't been an issue till now - sorry for the long story , and all help will be appreciated - Good day to everyone
B
boatman3162
Staten island
Also installed an after- market alarm 10 years ago and re- wired new front speakers - again, hasn't been an issue until recently
turkeybird56
Central Texas
@Wild one
The 08s use win module or RF hub?
Sounds like either Win Module/RF hub issue
Get one of these and start with the simple tests first a battery load test.These are still the best tool a home DYI'er can have in his tool box. Just because the batteries relatively new,doesn't mean it can be all that good.
Mojo88
Rhode Island
'19 Longhorn Gen5 ORG
Hemi 5.7L non-eTorque
Did the alarm installation include remote start (not sure if your truck had one from the factory)?
Anyway, I have seen a few issues with aftermarket alarms causing problems like this, as they often contain kill switches of some sort. If you have the alarm instruction manual, perhaps you can see if there's an easy way to disable or bypass it, then test and see if truck starts normally.
B
boatman3162
Staten island
A little update - Found the aftermarket alarm cutoff under the dash - tried starting the truck with both the alarm on and off - No change , still intermittent no start no crank - Had battery load test and that seems to be fine - i guess the next step is replacing the win ( wireless ignition node) ? Being that is have that maxcare warranty , i made an appointment at the dealership- hope my baby holds up another couple of weeks
Dean2
Near Edmonton
Just an update - ground from battery to engine block was corroded, changed it out and problem solved - Thanks for the input
Surprisingly, that is not unusual. Bad battery, followed by bad grounds are the cause of a ton of issues. Everyone wants to jump to the expensive parts canon first, basics often solves it instead.
xtryfun
US
Sounds frustrating, man. Since the dealer already swapped the starter and you’ve got a healthy battery, I’d start looking at the ignition switch or possibly the WIN module (that’s the wireless ignition node where your fob goes in). Those are known weak spots on 4th gen Rams and can cause the exact intermittent no-crank issue you’re describing.
Also worth checking grounds and wiring—especially if you’ve got aftermarket audio, sometimes a bad ground or a rubbed-through wire can throw the system off just enough to prevent cranking.
If you want to rule things out quick, try a spare key fob, or even wiggle the fob while turning to see if it catches. If it does, that points straight to the WIN module.
By the way, once you get this sorted, and if you’re planning to clean up the truck’s look a bit, I recently came across xtryfun touch up paint kits. Super handy for hiding those little scratches and chips these Rams love to pick up. Not gonna fix the no-start issue, but at least the truck looks fresh while you chase it down.
Dean2
Near Edmonton
Issue was already solved and the OP was good enough to actually post the fix.. Read the two posts above yours. . It was a simple bad ground.
