bigred318
i have a loose steering wheel. checked the big nut under the airbag, column bolts etc.. wasnt it they were all tight. so, i hear of this rock solid ram steering fix thing and how awesome it is. got it, installled it, no dice. still there. if i put my hands at 3 and 9 o'clock and push with one hand while i pull the other i can rock the wheel back and forth. also i can slightly slide the wheel up and down side to side. when i popped the hood, this was where the play was coming from. is there a bearing of something i can replace? its a 98, i dont feel like going to the dealer cause they will in fact say i need to replace the column... i guess its not a problem til the wheel comes off in my hands and i need to make a turn
