steering stabilizer recs
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Have had a slight vibration in my front end when under load. Not so much since I replace my front shocks, and one side of the antisway end links. I will be replacing the other side soon and hopefully that fixes it, and I will also install my drop brackets.
I was also told I need to replace the steering stabilizer shock as its leaking. Any recommendations? I would like the dual bilsteins but that is out of the budget.
rambob
LA/MS
318 5.2l
its likely not the sway link, mine is bad. it just knocks when you turn or hit a bump.
I have had success with rough country products on my jeep. their steering damp was a larger rod and fluid capacity over stock.
looking at the site, its $50 and its the same pn as the 2500 and 3500 models.
wermbang
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
thanks for the info will look into that. Is there a benefit of have duals? Eventually I will be running 35" tires but not sure when
iSlacker816
Kansas City, MO
5.9 (360ci) Magnum
Dave is the guy to ask there luck since he has his dual bilstein stabilizer
wermbang
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
^thats what I think I will do. Now to price search.
2K10HemiRam
Hometown: Tacoma, WA Stationed: Alamogordo NM
I put dual rough countries on my old truck and it helps out a good bit. Duals just help keep your wheel straighter under more stressful conditions. For example, it can get really windy here in Vegas and on really bad days, I would get hit with strong gusts and it would move me over a little bit while going down the highway. After I put the duals on, the same winds could hardly budge me. Another reason I went with a dual setup is because I simply liked the look.
wermbang
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
anyone ever used the Moog Steering Damper?
I am heading to advanced here in a bit to pick up anti sway bushings, and a moog bar end link. Thought about picking up that kit.
Johnnguyen6596
