Steering upgrade recommendations
Z
zpaulis1
5.9L 360
Another question, will my brakes all bolt up or will I have to get a new master cylinder for the 3/4 brakes??
Johnn123
Ontario
What size calipers ya have 7500 gvw or the 8800 gvw ones? 8800 gvw ones I would get the larger master cylinder, i'm not sure on the 7500 ones. If that makes sense lol.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
1996 is the the 12 valve :)
I think you're right though.
Actually, 94-early 98 is 12v. ;)
As John said, it depends on what brakes it has. 8800GVWR brakes are the best to have but they also require the matching master cylinder.
Merc225hp
NA
truck
gas
Dana 60 or 70? Can't find any numbers..
See that metal tag held on with two bolts, take it off, clean it wire wheel it whatever that has your diff info on it, it is also stamped into the drivers side diff tube clean the tube and look for it.
Get all your Q's into one post and I will answer them as best I can.
Z
zpaulis1
5.9L 360
Found out today the new axles have the 8800gvwr brakes.
Johnn123
Ontario
You'll need the larger master cylinder then I'm pretty sure. Started the swap yet? :D
Z
zpaulis1
5.9L 360
Alright sounds good.. Think that takes care of just about everything. Thanks for all the help guys! And no I haven't started the swap yet, I'm overseas right now but will hopefully coming home for Christmas to do the swap
Johnn123
Ontario
Not a problem, be sure to come and post lots of pics when ya do!
Z
zpaulis1
5.9L 360
About 1 month away from attempting this axle swap and 4.56 gear swap! Question that popped into my head... You guys say the front driveshaft won't need to be modified but wouldn't a D60 have a bigger driveshaft u-joint than my stock D44?? So wouldn't I need a conversion joint or something?
Merc225hp
NA
truck
gas
In my case I did not, just used the whole front ds that was in the truck, they will have the same u-joints.
Z
zpaulis1
5.9L 360
So your saying the D60 front will take the stock u joint on my stock driveshaft? Or I'll need the 3/4 front driveshaft?
Z
zpaulis1
5.9L 360
Alright one last question merc, im trying to order that 1410 weld yoke for the rear but I'm overseas so I can't measure the dia and wall thickness of my current one to buy the correct 1410.. Is there a constant spec on these or do they differ throughout other 96's?
Merc225hp
NA
truck
gas
Nope, I have ds here in the 3.5 and 4" range, as for wall thickness no way to tell until you cut the shaft.
Z
zpaulis1
5.9L 360
Fantastic -_- thanks for the help though merc
Merc225hp
NA
truck
gas
Anytime man and I will be around over the holidays if you need help.
fastSdime
Westmoreland, KS
1999 Ram 1500
5.9 Magnum 360
I have the T-Steering in my ram and it was all bolt in and I LOVE it. Was the best thing I ever done to my truck.
Merc225hp
NA
truck
gas
Which year are you using the 98.5 or the 08 steering? You do know that there is a difference in the tre tapper right. You might also look into the recall that is going on with that steering setup.
