Which year are you using the 98.5 or the 08 steering? You do know that there is a difference in the tre tapper right. You might also look into the recall that is going on with that steering setup.
This on the Dana44?
I've never done much looking into the setup, so how do you specify what steering linkages you get?I have the 98.5. I went thru everything that they had on DodgeTalk for what I did. I replaced the cheap ebay setup that I bought first. With parts that I can pick up at my local parts store that has a lifetime warranty. Its been on my truck for 2 years now and I love it. The ebay stuff just had cheap TRE and didn't last. The differents of the TRE is at the pitman arm. And the one that was for my truck and the one that I ordered for the 2500 HD setup have the same part #. I have a 99 1500 with D44 up front so I don't know about how it is with his but it was all bolt on in my truck.
Yes this is on my dana 44
Once again, Merc, the go to man for part numbers!
Fast, you say your bump steer is just about gone, what stablizer are you running? Mine is stock and i get bump steer pretty bad on the street sometimes. lol
I don't have a stablizer on my truck. Due to the crossbars are MUCH thicker then the stock 1500 and the bracket didn't fit. So thats just sitting on a shelf in my garage.
Merc, you say the steering stabalizer doesn't do much. Right after I put in my 5" suspension and 3" body with the 37" boggers on my 1/2 ton axles I was getting pretty bad death wobble after about 35/40 mph.. I just ordered an extreme duty track bar from DOR and as u know I will be installing the 3/4 ton axles.. Do u think a dual stabalizer setup would benefit me?? Also took my sway bar off after the lift because I didn't think it was beneficial
No stabilizer and no bump-steer?
As for not running one at all, I swear all trucks are different. Like Merc, I've heard of guys not having run one since day one, and other guys having to run them. I'm starting to wonder if I'm one of the guys in the latter category.
No I do not think they will help at all. If you're a mud bogger with like 40+ tires and making big hp then thats a different story. If you want them get them for looks. Do some reading on steering geometry, its somewhat basic stuff but very important. A good well set up steering system will work wonders, tight everything a good alignment and the 60 will do wonders. I am sending you a pm regards to steering.
All the big 4wd trucks I have owned over the year's I have never used a steering shock, and this one is not the biggest by far..........yet. Biggest tire I have ran was old 44" Ground Hawgs back in the 80's.
^^^ Yeah much worse than these lol, these trucks steer like a dream compared to older 4wd trucks with big tires. For you to get rid of your bump steer you will have to change things in your panhard bar set up or track bar as we call it.
Edit: Bump steer in this trucks was almost built in at the factory.
