jshatch
Hi, I've looked around and haven't found any posts with what appears to be exactly my problem. I noticed a slight squeaking noise coming from the steering wheel when it's turned, doesn't matter how far, or if the truck is on or off. The posts I found suggested things from loose bolts in the steering column to low PS fluid. Well, it appears the noise is coming right from the base of the wheel, and if it happens when it is off I don't believe PS fluid has anything to do with it.
To make sure I describe it right, here's a video that shows it in action with the truck off and parked in my garage. https://photos.app.goo.gl/iHMRT4i9VRkYvk7JA
Any thoughts?
Any thoughts?
