Steering Wheel Upgrade/Swap
Bub16
Chicago
5.7L hemi
I have a 4th gen 2016 Ram 1500 Express with the stock steering wheel it came with. I’d like to swap it out with a 2019 new style steering wheel. I attached representative photos of both styles. The one I currently have, has the smaller gap at the 6 o’clock position . Has anyone tried this? Is this possible as far as compatibility goes (spindle, wiring, etc)? I’m sure I’d have to get the new style airbag as well.
Brandon-w
Yukon
2015 Ram 1500
This will work yes. The ram spindle works from 1995-2024 its the same the buttons may be a bit different I lf I remember correctly the shifter buttons won't work but all other buttons should work. I think the circled buttons would be your shift buttons.
When I was testing all the buttons worked except the shift button on bottom right but that was it. I modified a 5th Gen limited steering wheel for paddle shifters for a customer when I discovered this.
Bub16
Bub16
Chicago
5.7L hemi
Thank you for the response. One question, is the wiring connectors all the same or do I need to get an aftermarket wiring kit?
Brandon-w
Yukon
2015 Ram 1500
The wiring was the same on mine. That I can't guarantee will be the same for you it should be a white connector that goes into the clock spring though.
noraa73
