Stereo problem
Eric0782
I have a 2004 Ram with the Infinity sound system and in-dash navigation system RB2. I had the system replaced last year with a refurbished unit. Last tuesday I drove the truck for a total of 20 min, stereo worked fine, when i got back in the truck 30min later the stereo didn't come on or even light up. Though if i turn the ignition on and the parking lights on the stereo lights up but immediatly shuts off the minute i hit the power button or start the engine. I've checked the fuses and the wiring everything seems to be getting power. Is there any advice on the matter or would it be better to just replace the whole stereo system??
bigbadram1500
Springfield, IL
Welcome to the forum. :) Not sure what your issue may be, but am bumping so others can chime in and help you out.
HemiBabe
DFW
Welcome,
I would guess that the radio is just about to crap out....
rex450se
Independence, MO
4.7L
I'm only thinking this because of the stereos behavior with the ignition turned, but maybe a bad ignition switch. I really have no idea, but it might be something to consider.
Also, welcome to the forums. I haven't been here long, but like it already.
Victor
shimmy2169
Minnetonka, MN
yes it sounds like an internal problem in the deck to me. Would you happen to have a warranty?
Eric0782
Eric0782
Warranty expired about 3 months ago on the unit. I ended up having it tested and come to find out the power supply crapped out on it. I am now looking into an aftermarket set up but tend to find very little info on wiring around the infinity sound system.
ramfanatic
Banned
check the grounds on the radio had same problem with a aftermarket radio and it was the ground wire not making good ground
Chirnak
