Stock LED taillights
RamCanadian
HEMI 5.7
How would one know if they have stock LED taillights?
Looking at Anzo aftermarket tail lights and see this:
DOES NOT FIT RAM MODELS WITH STOCK L.E.D TAIL LIGHTS
RHeller
usa
Here are pictures of each. One uses Led bulbs and the other uses standard auto bulbs. The led tail lights look like there are horizontal strips inside. Top are led bottom are non-led
cgeorgemo
Joplin, MO
3.6 Pentastar
Or if you're on a computer with a wide screen Left is LED right is non-LED.
dkmesa
if they use led bulbs....
EagleChief
Oklahoma
2014 Big Horn
Don't mean to hijack the thread, but...
Will the stock LED lights directly replace the standard light set up? I just bought a 2014 Big Horn that has the standard tail lights. Saw a truck with LED's that I'm pretty sure were factory. Now, I'm curious if they can be switched out and be plug & play?
cgeorgemo
Joplin, MO
3.6 Pentastar
You will need a set of adapters to keep from getting hyperflashing and bulb out errors. You can get them from JJ at the retro shop.
BlownGP
Houston/Baton Rouge
Will also need the adapters to convert to the LED lights.
Doc1609
Missouri
Led oem taillights will have mopar stamped in the lens if your comparing to an aftermarket replica
KAKA
