Strong Antifreeze Smell
GWOTRGR
SC
2020 Power Wagon
About two weeks ago I noticed the heat wasn’t blowing as hot as it normally does. I thought to myself, I guess the heater’s going out. Yesterday, steam started existing out the dash windshield defrost vents causing a large area of condensation build up on the inside of the windshield. Turned the AC on and it starting blowing out the AC vents. And there’s a strong smell of antifreeze inside the cab.
What’s broke and how do I fix it?
olyelr
Kewadin MI
I've been getting a whiff from the engine bay here and there, no drips on the floor. Oh, boy. Known heater core plugging issue.
Well I guess it's cheaper than a new truck. *sigh*
I had that minor/periodic antifreeze smell since my truck was brand new. 8+ years later and 120k miles i still get it once in a while. Never been low on coolant, never added any, and its never been changed.
GWOTRGR
GWOTRGR
SC
2020 Power Wagon
Just got home from work. Blowing steam/smoke out all the vents and went up to 251 degrees a couple times.
olyelr
Kewadin MI
yea you are going through coolant somewhere and its probably super low. Definitely dont be driving it like that and overheating it.
GWOTRGR
GWOTRGR
SC
2020 Power Wagon
Yeah, going into the shop first thing in the morning. Any idea what this is going to cost assuming it’s the heater core?
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
If you can do without the HVAC until you can fix it.
Remove the whole Air Filter Box ,
( There are YouTube Videos about it, it is very simple to do )
Under the Air Filter box, you will see 2 Heater Hoses.
I would install a U shaped Plumbing Fixture on those hoses, or something similar.
That would keep the Coolant out of the Cab
IF , you do use Needle Nose Vise Grips, like the mechanic is using.
Slip a couple of short pieces of Hose over the metal grips
GTyankee
3.0 ecodiesel
IGNORE my post above :
When the mechanic has the HVAC Box out of the Ram ..
Make sure that they check 4 or 5 Doors & Actuators, before they re-install the HVAC Box
The Doors inside the box are :
1 Recirculation Door & Actuator ...
at least 1 BLEND Door & Actuator(s) ..
2 MODE Doors & Actuators
the actuators are mounted externally
The DOORS are inside of the HVAC Box, they can be checked Electronically or Manually
The broken Doors are only accessible, when the HVAC Box is outside of the truck
The Box would have to be OPENED UP, in other words, it would have to be split into 2 or more sections
GWOTRGR
GWOTRGR
SC
2020 Power Wagon
HVAC or no HVAC it’s still blowing steam excessively through all vents and running hot. I was told the heater core is behind the dash and it’s a pain to get to?
GTyankee
3.0 ecodiesel
The HVAC Box must come out to replace the HEATER CORE
When the mechanic pulls out the HVAC BOX
RE-READ my POST # 9 before you have him do the work
IF the Doors are broken , the Mechanic MUST FIX any Broken doors when he fixes the Heater Core
GWOTRGR
GWOTRGR
SC
2020 Power Wagon
IF the Doors are broken , the Mechanic MUST FIX the doors when he fixes the Heater Core
Thank you
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
6.4L HEMI
theres a small hose on the fill tank that lets off vapors. you can rest easy now
Isn't there an overflow vent tube on all bottles? This is the only motor I smell it on. And yet, the coolant level in the bottle is constant. Ah, well.
crazy jerry
WY
im not sure about all other vehicles. all i know is my engine bay has the coolant smell but ive not had to add a drop in 7yrs. im sure the bottle has a 2way cap that lets off vaper when it heats and builds pressure
olyelr
Kewadin MI
As does any vehicle, i would think. But i agree, mine has smelled like antifreeze on and off since brand new…never seen a drop, never added any, never been low…has 118k miles. Going on 9 years with the old girl
GTyankee
3.0 ecodiesel
The OVER FLOW hose & Tank are Not Sealed
Like the Radiator & HVAC Hoses are
When the pressure builds up, the radiator cap relieves the pressure & a small amount of coolant goes into over flow tank.
That allows the smell of coolant to escape
HEMIMANN
Minneapolis, MN
6.4L HEMI
Yes, so why is this the only engine I smell coolant from?
crazy jerry
WY
im not sure what your rambling on about but these trucks have no over flow tank. atleast the 6.4 doesnt. its just a expansion tank and is part of the sealed system. perhaps your refering to some other truck with some other engine.
and yes other vehicles can and do give off coolant smell. my car does it also. we may not always be paying attention or notice it though
crazy jerry
WY
and another thing regarding older vehicles (typically). the tank ,expansion or over flow, how ever you want to refer to it , serves the exact same purpose as the sealed tank , the older style just isnt part of the sealed system. its main disadvantage is it suffers from coolant loss through evaporation over time
