rotwiler
Last night I put some molded mud flaps on, put truck in reverse, when in D, noticed power was low, then saw 4 on dash and engine light on. Stopped on side of road, tried restarting and still was in 4, then after like 10 attempts was in Drive again, but 5 minutes later went back into limp mode and into 4th gear. So I went to dealer today, check engine light was on, but truck was shifting ok. Noticed eco mode was not coming on and auto start won't work. So dealer said they are booked up until Jan 2, 2018. I had them pull codes and came up P0750, which I expected, but odd code P0441 evac purge came up. Truck has never thrown a code before, so odd both came up at same time. So I thought, maybe will just get gas cap, I had filled truck day before when it went into limp mode, but had driven 30 miles with no code. So stopped at auto parts store, put new gas cap, started truck and there was no check engine light, truck drove normal and eco mode worked. Now I didn't start truck and let it idle before check engine light went off, instantly when I started it, was off, so I am confused if that was the issue or just coincidence that light went off at that time. Any suggestions appreciated. I only have 3 months left on power train warranty. Truck is 2013 Ram 5.7 QC, 2wd 6 speed.
