Sunroof Issues
Ramsfan78
St. Peters, Missouri
HEMI 5.7
So I noticed that my sunroof wasn't closing flush with the roof and was letting a little water in during rains so I decided to do a little research. What I found was directions on how to recalibrate a jeep sunroof which were the same as the calibration instructions for a SRT and since I could not find the directions on how to calibrate the sunroof in my 2010 Dodge Ram I figured what the hell, it has to be better than letting my headliner get water stains. The instructions say to push the "vent" button and once the sunroof opens to full tilt, release and then hold the "vent" button for 5 seconds. I did this and after five seconds I noticed that the motor clicked into place as if it were calibrating. Problem solved, right? No way! After I did this, when I pushed the button to close the sunroof it would go almost all the way closed and then act as if there was something preventing it from closing completely and it would open back up to about the half way mark. A little more research leads me to believe that it is stuck in the "pinch detection mode". The only way to get the sunroof closed completely now is to press and hold the close button for about 10 seconds and then it will close completely. My question is, is there any way to reset the sunroof or take it out of the pinch detection mode? By the way, after calibration steps were followed by pressing and holding the vent button, the sunroof now sits flush or in fact even a little higher than flush with the roof. Please Help. It's spring and I needs mah sunroof!
joshhhh
