Suspension Hits Hard on Bumps
Longhorn1500
West Sound, WA
2019 Longhorn
Cummins SO
I just returned home from a trip with the trailer. Since this truck is relatively new to me, I am still getting used to it. OK, when hitting a bump that hits both wheels/tires at the same time, like a joint at a bridge, the rear hits really hard. Almost feels like there is no suspension at all. I am not bottomed out on the snubbers. I first noticed it when towing the trailer for the first time and I thought it was bottoming out the suspension. I just installed Timber Grove ASAM air bags. It happens both when towing and when lightly loaded. If the bump hits each tire individually, there are no issues, only when both tires hit at the same time. Oh, I did have the tires inflated to their 50 psi sidewall maximum for the trip. I did just lower the air pressure (42 psi) and took a short drive, better, but still shocking. Thank you for your thoughts.
Mcicale
Arnold, MD
I did a Google search and found your post. I'm having the same exact issue with the same set up from Timber Grove. Did you ever find a solution?
CrasherAsher
Mesa
how much air are you putting in your bags? or does it do regardless if you have them filled.
