Suspension Lowers while driving
afram1220
New Jersey
I am looking for some help. I have a 2015 Ram 1500 Sport w/ air suspension and the rear driver side corner will lower randomly while driving. After it lowers the ride is extremely bumpy, as if there is no suspension. Then I pull over raise it to off-road 1 height and then back to ride height and it rides just fine. It also will lower just the driver rear corner while sitting there with no explanation. Has anyone had this issue? I know the air suspensions have had issues in the cold weather, but this happens even in the hot weather as well.
Any help is greatly appreciated!
blackbeautyhemi
Lewistown, PA
If you’re going 65 mph it’s suppose to drop down to aero mode but it drops down evenly and rides nice. Maybe a bad sensor? I’m not sure.
Tim7139
Alberta, Canada
2020 Classic ST Crew 4x4
5.7 Hemi w/8 speed 3.92 gears
Could have a slow leak, which also leads to running out of nitrogen. Could be a valve or sensor, but sensor would not fit well with height loss while off.
Jtucker21990
