Suspension Superstore 272920
Matt Franklin
Lexington, KY
Morning. I've been casually toying with the idea of leveling my '19 Classic Crew Cab 2WD 6'4" bed Ram. I've never lowered anything I've owned, so this is new territory for me. I want it to be a subtle change, and I definitely want the ride quality exactly as it is now.
I found a set of these on FB about 1/2 price:
2009-2018 RAM 1500 2wd/4wd Premium 2" Rear Lowering Coils - 272920 - Accessory Partners (suspensionsuperstore.com)
Has anybody used them? Any opinions or thoughts would be welcome.
Midnight Storm
One Badass Ram
Victoria, B.C Canada
You may see a pretty sweet review on there from my beast. There are 3 pics from different angles. I like them!
I’m going to go lower at some point.
FamilyWagon
NoVA
Yay. First post here. Just had these springs installed on my 16 Ram crew cab 4x4.
Made it nice and level. Rides same as stock. Absolutely no complaints. Looks perfect.
Valkyrie0002
Fredericksburg, Va
2017 Big Horn CC
I installed these almost 2 yrs ago, rides like stock. Only complaint is they bottom out easily. I cut the bump stops down about an inch. I installed a fiberglass cap a yr ago and the ride height still looks level. I have a set of Firestone in-spring bags I will be installing.
18GSMRam
FL
Those of you that installed these, what is the gap from bottom of fender opening to top of the wheel?
I bought a used 2018 and it surprisingly has no rake to it but I cant find any indication of aftermarket parts (either front spacers or rear lowering springs).
M
Matt Franklin
Lexington, KY
I didn’t wind up pulling the trigger on these, so I don’t have numbers for you. I wonder if your PO cut the stock springs?
18GSMRam
FL
thanks for the response.... Tough to tell but I did some reading and some have indicated the 4x4's sit higher in the front by as much as an inch or 2 so that could be it if true. The back looks like all other trucks I have seen stock, its the front that is considerably higher then the ones I have seen out in parking lots but I didn't check to see if they were 4x4.
