Swap 5.7 gs to 6.7 turbo diesel?
Kahrdcarrier
5.7 L
I have a 2005 Ram 1500 with a 5.7L engine with about 180K miles on it. The body is beat up, but that is the type of use it gets. I have the opportunity to buy a wrecked 2015 Ram with a 6.7 L turbo diesel with less than 21K miles for really cheap. The radiator, starter, engine and transmission are all OK. Will this swap work?
BlackMagnum2000
Locust Grove, GA
5.9 Magnum
Just a heads up, this section is for second generation rams (1994-2002). You should post this in the third generation section, or ask a mod to move it.
But to answer your question, highly unlikely. The 6.7 relies on a lot of electrics that your ecu and harness doesn't have. Not only that, all the egr equipment that your truck lacks. Front suspension would have a tough time coping with the added weight of the Cummins as well. Along with that, I'm not even sure it would fit. 2015 is a 4th generation truck. Totally different from your 05.
So.. yes, it's totally possible. Everything is possible. But it would take so much work to do, I wouldn't at all suggest it.
Csanders1992
You'd be better off fixing the 2015 and keeping the 05 the way it. Your truck is not designed to handle the torque or the weight.
phorrestphire
