Swap in a 12 inch?
limechallenger
South of The Motor City
2014 Ram 4x4 Sport regular cab
Just wondering if I buy a 2020 Rebel with a 8.5 screen, can a 12 inch be installed if I buy all the correct trim pieces?
Jack usrey
Lebanon, TN
2021 Power Wagon
Hemi 6.4L
I'm trying to do the same thing with my 2021 PW. I found a YouTube video that indicates it's not that hard. It requires pulling the two screws in the sunglasses holder (under the protector), several retainer clips, the 8.5 inch screen, and multiple wiring clips. Then the guy plugged the wiring clips into the 12 inch screen, popped into the clips, and installed the screws. What he didn't mention was if there is a need for a software update. I'm still researching. I want to upgrade the screen and add the 360 cameras, so please let me know if you figure this out.
Jimmy07
It’s pretty easy, and many people have done it (just not on this particular forum). Basically, you need the 2019-2021 12” screen, the 2019-2021 radio module, the center dash screen bezel, and a short adapter cable. You will also need to use AlfaOBD to change some settings to get the new radio to work properly.
gofishn
Iowa
hemi 5.7L, 345 cu in
read the thread title and my very first thought was;
Hope he asks the wife , first
My Wife is Rught - I'm nor Normal
MattsRam
Pennsylvania
#jimmy07 What short adapter cable do I need for this? Also, do have a list of the settings needed in Alpha OBD? Or could you point to a thread that has this info?
glsander
