Swap unlocked PCM. Truck starts then Dies.
Josh22855
Long story short. Did an engine swap between a 2016 and a 2017 ram 1500, both having a 5.7L engine, well immediately after doing this my 2017 ram oil pressure sensor is always reading between 97 and 101 psi even with the engine off. I swapped oil pressure sensors and it still is doing the same thing.... so I am leaning towards there being an issue with the PCM. I have another unlocked PCM so I tried to use it on my 2017 ram, it starts up immediately but then the engine dies within 2 or 3 seconds. Is the PCM vehicle specific? They both have the 5.7 and both have the 8 speed transmission and both Pcm's are unlocked.
Matts175
My understanding is that the PCM is set for s specific VIN and will only work in THAT truck.
Josh22855
Josh22855
Yeah that is what my thoughts were as well but when I called diablosports they told me it would work.
I'll probably have to mail them the PCM and give them the vin # for the 2017 ram and fork out another 200$.
Mordechai
St. Pete, Florida
You can use Alfaobd to change the vin of the PCM/ECM
Sent from my ONEPLUS A6013 using Tapatalk
indept
South Jersey
Do you have to program the keys with a new pcm?
Brandon-w
Yukon
2015 Ram 1500
Did you do the throttle body relearn when you swapped pcms??
Sent from my SM-G981W using Tapatalk
JLEONARD
Massachusetts
5.7L
Do you have the tutorial on how to do this? Dealer told me this cannot be done. Bought a PCM off Ebay, its the right one but don't know exactly what year it came off of or what it had for specs.
Johnnguyen6596
