swaybar links......nom nom
ramhunter9
P-Star Jeep Wrangler
Give me a sec and I will link ya .. I had the same problem on my 04 with the 2.5 level
ramhunter9
You can use these to retain the OEM links . Drops the bar down . Since you already have the new OEM links . Easy to install . If you need me to do it let me know 15 min job . And as you can read .. A must for 2.5 levels on stock links and a vendor on here ... so 45 plus the discount .. CHEAP .. never have to replace links again
Dodge Ram Anti-Sway Bar Drop Bracket Hell Bent Steel
ramhunter9
NP , that drops the bar down so you can use OEM links .. if not its allot more for longer links . I ran this kit on my 04 SC with the 2.5 level .. worked like a charm with OEM links
You need help with install bring the truck over .. easy job
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
HBS.com said:
*Note: the drop brackets will not fit the 1500 IFS models
you sure these will work on her 1500 man?
ramhunter9
They were the ones I used on my IFS ..
Ask HBS in there room I guess
ramhunter9
Ahh crap your right .. SFA only .. I could have swore I used them on my 04 ...
Back to the drawing board
ramhunter9
I am on drugs ... A IFS truck like yours does not have end links .. did you mean ball joints ?
bigbadram1500
bigbadram1500
Springfield, IL
ok now I'm cornfused LOL don't I have an IFS on this truck?
edit: wrote this before I saw you guys' comments
ramhunter9
You have a SFA front end ? NAH not in a 1500 you should have IFS
bigbadram1500
bigbadram1500
Springfield, IL
yeah, that's what I was asking, I thought it was an IFS but wasn't 100% sure. I'm gonna post up a pic of the swaybar end link.
ramhunter9
That will work
ramhunter9
pic of the sway bar that is mounted to the top of the links ?
EJM05
Somers, CT
440 Big Block
Ahhhh I'm confused. Yes you have a IFS front Wendy.
ramhunter9
Ya like in the HBS link
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
Take a pic of the bracket were the sway bar bolts to the frame. I have some extra drop brackets that came with my lift. They should work. I'll take pics ASAP.
Droid Incredible 2 on the move!!!
