Ramnewbie: This is just me & my one sided opinion.
I have a hard gut feeling it has to do with $hit poor roller lifter design & oil psi with normal operating temp excessive idle time.
Thus the reason the Moly plating of all these high pressure moving parts is so critical.
Just my opinion!
There is ALOT of things that I can see in this small complex ******* going bad if the perfect ideal situation is disturbed.
What’s worse is there are more then 1 of these little GEMS within the upper half of this motor where oil flow/psi is less then perfect when the motor is at operating temp @ a stop light with your foot on the break.
Once again just my simple minded outside the box thinking.
