ramffml
- Jul 12, 2019
- 2,835
- 5,225
- Location
- ramforum
- 2019
- hemi 5.7
Whatever works should be considered imo. The good news about the way you killed your tick is that for sure it isnt a "mask" because things associated with that would be going thick instead of going thin. So whatever happened to your tick just by that action as long as the tick stays gone you fixed the issue. Like I was saying there is little risk to trying it, and perhaps some other benefits to doing so. Especially if you used it as a flush towards the end of an interval.
But also everything kyle was saying is 100% truth as well. So some ticks as in your tick can be killed by thinning and cleaning your oil with a solvent can kill some ticks. And for someone considering a more traditional approach would this not even be a good idea before even buying the redline or biotech? You can drive 50-100 miles as a flush, you can wait to see if this strategy works before even buying biotech or redline, if by chance all you needed was sea foam through the sump, boom you win. It still wouldnt be a bad idea once you have a tick to use ram forum developed strategies, even if sea foam solved it before even trying those, because those strategies include running known additives that help cams, in fact used to install all cams in the first place with the use of moly.
So even if sea foam works, then what becomes the question. And there is no such thing as sea foam not working, because you would have accomplished something by using it, at a minimum you used a gentle flush before you changed the oil, so benefit happens if hemi tick is gone or not. My definition of strategy is you put some thought into in based on science. So if you killed tick your strategy is whatever you say it is, and if it is castrol of whatever and it continues to keep hemi tick away, you win. Try some things, this is a legit choice, just another tool in the hemi tick tool box.
I should review my history because I had recently seen a vid where some guy made his hemi tick 80% "better" by adding lucas. Now, this is an example of masking, an example of something that can actually do more harm then good in the long run if it keeps you away from a solid strategy that actually fixes the situation. There are also more ways to test if a strategy worked or not then just hearing tick, you can also do uoa's, if you truly solved a hemi tick situation you will see wear numbers tumble from when you have hemi tick to when it's gone. So maybe the first thing someone with new tick should do, get a uoa, try some things, see what works to lower wear and keep the tick away.
One of the theories out there for causing tick is that the needle bearings get gummed/varnished up and either become slow to roll or eventually stop. I can definitely see how a cleaner would help in this situation.
Also some oils have exceptional cleaning ability, that is also an option as opposed to using seafoam which I understand is rather harsh on the system.
