Synthetic Oil
Oil of Choice
  • Castrol Syntec/Edge
    Votes: 237 8.5%
  • Royal Purple
    Votes: 327 11.7%
  • AMSOil
    Votes: 400 14.4%
  • Valvoline Synpower
    Votes: 160 5.7%
  • Mobil 1
    Votes: 997 35.8%
  • Other
    Votes: 663 23.8%
  • Total voters
    2,784
R.L.K.
Bristol , Tn.
Good lord I posted this in the wrong place[emoji23][emoji23][emoji23][emoji23][emoji23]
Hope Ron misses this one[emoji23]
Carry on[emoji2957]
Idiot[emoji23]
wgreggking
rural Arizona
2017 4x4 offroad
Bro, I quoted Dexter, then you quoted me talking about Dexter, and I responded about* Dexter. He spams that comment literally any time anyone asks about running X oil or a UOA. Come to think of it, I think he is the one @Burla blocked because of posting stupid (spam) comments...
Edit*
OK, Point noted, Sorry.
wgreggking
rural Arizona
2017 4x4 offroad
0W40 was not successful in my truck regardless of the brand even redline. A simple jump to redline 5w40 fixed it.
I may just try RL 5w40 next oci, was concerned about warranty,but.....
I NEED SOME PEACE AND QUIET.
U&A
2016 3500 SRW
6.4 HEMI
Give it time and she will quiet down with this oil.
Remember if you’re running a larger filter to an extra oil
wgreggking
rural Arizona
2017 4x4 offroad
I'm using RP 1048. I cut open the last 3, no metal or anything sticking to a magnet. Those suckers are well built. If I go large how much more oil? I always keep the dipstick at or slightly above the line.
U&A
2016 3500 SRW
6.4 HEMI
About 1/2 quart extra (no less) is good for the large filter.
R.L.K.
Bristol , Tn.
So hows everyone doing ? I dont get on here to much as I have working on getting my Nova up and running.
Just picked up 5 quarts of Penzoil and have a RP filter coming for it , After I get a few thousand miles on it I am going to switch it over to RL as well.
Still running RL in my Ram and still very quiet at 32k but the oil temps sure runs warm , keeps any moisture burnt off anyway..lol
Does anyone think going to 5w20 would lower the oil temps ? I have seen in the high 240s in the summer.
I dont know maybe I should not worry about it
None Ram related pic..lol
Long time no see Sir . Too Long [emoji106]
Car looks great !
I think it's awesome that your giving the car to your daughter , well kinda giving it to her [emoji23] still Daddies car right [emoji106][emoji106]
A big NO on dropping to 20wt imo.
Stick with the 5W-30 Redline.
Your towing oil temps are on target imo[emoji106]
Redline 5W-30 has fantastic thermal stability and is still very stable above 275° from what I've read .
I've had my Redline 5W-30 oil in the high 250s many times and once above 260° in the summer while towing 7k up into the mountains and my UOA showed near Zero breakdown in viscosity ,not to mention Great wear #s at the same time .
I'd bet your non towing temps are between 210-220° ? If so again if so on target imo .
Nice to see you back around my friend , looking forward to more pictures and videos of your "daughters" car [emoji16]
Hemi395
Cape Cod MA
@Burla or anyone of course, i have a curious question. I know there are many many , disagreements on many different topics on here, but i was thinking about one in particular.
Its going it sound like an MDS question, but more of an oil question. I'm wondering the people having same truck/year/engine with the complaint of "feeling" the MDS kick in, (that would be me also), vs the ones that swear they don't. I'm excluding if the newer trucks may have fixed the issue. I'm wondering instead of there being just people bickering back and forth about it, are they actually all correct. In other words there are trucks/people feeling it and others actually are not. Heres the question.
Is the oil type, more so the WEIGHT, the difference? Don't know if this warrants a poll, but maybe just some chiming in. Heres why i may think this. I swear when i bought my truck, i hardly noticed the MDS, and DEFINITELY didn't have the lag when wanting it to cut off. So is the thicker oil delaying, for milliseconds the kick out, not enough to hurt anything, not enough to ever cause a CEL. Just enough to notice.
Mine is extremely noticeable when it kicks out MDS. It's like a transmission downshift almost. I've had mine turned off for awhile now and it's so much more responsive. The type and weight of oil did have some affect on how smooth it went into MDS but nothing has changed how it comes out of MDS.
Also as a side note, I've not noticed much of a difference in MPG with MDS off, MAYBE .5MPG on the highway. I think this is because the injector pulsewidth doubles for the 4 active cylinders while the 4 MDS cylinders are inactive. I made a thread a couple years ago illustrating that:
https://www.ramforum.com/threads/do...&share_fid=17770&share_type=t&link_source=app
Not really sure how that's supposed to save fuel if the 4 active cylinders dump double the fuel in.
JMO, I think MDS is a marketing gimmick and a solution for the EPA to get the CAFE up a bit.
U&A
2016 3500 SRW
6.4 HEMI
EXACTLY!!!
Its all politics! And ALL *********.
U&A
2016 3500 SRW
6.4 HEMI
RP 20-820 oil filter fit 6.4?
Yup yup,
PLENTY of room.
Clean the meating surface that the oil filter ring contacts when switching to the larger filter. The OD of the ring is ever so slightly larger.
Zack02
U&A
2016 3500 SRW
6.4 HEMI
Going from a lean running 8 cylinder to a rich running 4 cylinder while the other 4 are doing compression strokes without detonation is a HUGE! change in power output.
Oil will not make a noticeable difference in the “feeling” of MDS coming on and off IMO. If so it will be very little.
The simple fact that you have extreme power surges instantly your going to feel it and the trans and driveline will absorb the abuse from it.
Its a STUPID design.
And on the same note where Corey mentioned how you get double the fuel pressure in the active 4 cylinders..... there’s no way in heck the EPA does not know about it. They’re simply collecting their check and they’ll do nothing about it. All about money.
OCDTech
Louisiana
The simple fact that you have extreme power surges instantaneously your going to feel it and the trans and driveline will absorb the abuse from it.
They have to show they are playing the game. Yep.
No what i meant by feeling. Was the theory that rhicker oil maybe was delaying the pin in the lifters unlocking. In other words signal from pcm is sent but delay was thickess of oil.
But your right they know
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
Car looks great !
Thanks for the info it does make me feel better that others have the same type of temps. Will just keep motoring on with what I am using. :)
I was able to set the motor in place last night and bolt up the transmission , still have a ways to go and waiting on my parts to come in.
