Tailgate spoiler
Dave Haddon
Saskatoon SK. Canada
Just to confirm these aftermarket tailgate caps/spoilers they are just kept on with 3M tape right? Kinda scary they might blow of or be removed..??
mikeru
Super Moderator
Moderator Supporting Member
2020 Limited
Hemi 5.7L non-Etorque
Pretty sure there are plastic tabs or clips as well as the tape based on a pic of the top of the tailgate, with no spoiler attached...
Found a pic of the spoiler. You can see the clips on the bottom for mounting. I think there are also screws on the leading edge as well...
Edit: Just realized you were asking about aftermarket spoilers (d'oh). You'll have to check with the seller of said spoilers to know for sure.
Bigskyroadglide
Moderator
Member Relations Specialist
Montana, officially RETIRED
Hemi 5.7, supercharged
Op,
Not certain I follow you. I have a Crespo wing, manufactured by Street Concepts
And it's attached in the same format as the oem tailgate cap with the exception of the top snap in pieces.
Per the pics attached, you can see I upgraded from the plastic inserts to screws
And developed my own brackets to avoid a 3m tape only mounting process.
By far the hardest pieces to mount were the corners which are designed to be molded into the bed side.
Say what you will but I've seen well in excess of triple digit speed since mounting and no movement.
To steal it would require access to the bed, but that is locked down with a cover and the tailgate locks, so it's going to take someone really looking to create mischief with your truck to get one off.
My thoughts
natehate
ontario
Op,
My thoughts
do you have any pics of this spoiler?
Dave Haddon
Dave Haddon
Yep.. sorry for the vague post.. after market spoiler.. they seem to just fit over the OarM one with tape. …I guess it will be OK
Dave Haddon
Dave Haddon
That looks really sharp. Just not wanting to do screws and such. Nice job on yours though real nice
Bigskyroadglide
Moderator
I didn't drill a single hole it the truck, all existing bolt holes. The two photos of lag bolts go into the bed into a factory hole under the plastic on bed sides.
Bigskyroadglide
Moderator
Marshall
Sk, Canada
2014 sport
What about the ones on the older Daytona trucks? Son has one, but the spoiler was gone when he bought it used, there is one one running around town, but I don't know who the fellow is.
They go on the box rails I think .
More of a wing I guess.
