Tailshaft
Waynesrage54
Magnum 5.9
I hqve a 1995 dodge ram 1500 5.9l What is the seal called for the tail shaft that the rear driveline goes into
The War Wagon
da' 'BURGH
318 Magnum
Check your Timken guide - don't skimp on an drivetrain seal!
bassslayer25
East, Kansas
5.9 360 V8
Yes. A bad pinion seal will allow dirt and other **** in your diff and cause **** to break.
Rustycowl69
2001 ram 3500
V10
are you kidding me? aren't you talking about the rear of the transmission tailshaft? I believe that seal is technically speaking, a rear seal.
ramburger
tricky seal to get in.
grab a t-case saver while yer at it super cheAp
W
Waynesrage54
Magnum 5.9
Alright thanks for the info guys
Raadz
