Tank strap recall
Jeepwalker
WI
2012 Reg Cab, 4x4
Does anyone know what their 'fix' is?
I wonder what they do if there's a hole rusted in the frame?
Tach_tech
5.7L HEMI
I imagine the recall will be similar to the TSB that was released early February for this issue. The repair was to cut out the rusted metal and install a new fuel tank strap bracket.
averageguy
Belleville Mi
hemi
That bracket must be junk because the under side of that truck is way to clean for that strap to be rusted in two by comparison.
Villanova
That's what happened to my '01 Ram. The strap holdings the front of the tank broke and it was dragging the ground. No cheap fix, traded it on a new '17. ftd
T
Tonyd76
Seymour CT
strap was fine- when i was undeneath, there was some leftover ice/slush from that morning that was in the area where the bracket is- must be the reason why it rusts out, the snow and ice gets trapped in between and settles down into the bracket.
grizzstang
Calgary, Alberta Canada
The Ford F150's from 97 to 03 had this issue too except the whole tank would drop onto the road unless you had a model that had the tank skid plate. Pretty scary what could happen if this went really bad.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
The design would be fine if they would have put in a weep/ drain hole. They didn’t and the moisture sits back there and corrodes a lot like the wheel wells tend to do. I am sure the recall “fix” will take six months to get “in stock.”
DA67Goatman
Ohio USA
I just had the same happen to my 2016 so they never fixed the problem and mine isn't covered by recall.
ranchhopper
illinois
My neighbors broke and the front dropped down while hooking up to a horse trailer lucky they noticed it before leaving the yard. Reminds me of the way the forward spring hanger for the rear leafs on the square body chevys used to rot the frame behind it when rocks would close up the drain hole and salt and dirt piled up in it and held the moisture against the trucks frame.
Tach_tech
5.7L HEMI
There’s an extended warranty for the fuel tank strap. Pretty sure it’s a 12 year unlimited miles for 09-18 models. Call your dealer and ask about it.
blackbetty14
CT
Hemi 5.7 VVT/Etorque
Easy fix, squirt fluid film in there. I did that to a few key points that I learned from my 2014 express. Fluid film can’t wash out and it can’t rust out/off. Front holes on the leading edge of the hood spray toward the front edge and you won’t get rust bubbles on the outside edge of the hood by the grill and headlights.
broncobill
Muskegon
On my 2015, this happened this past Saturday. Used a ratchet strap to secure the tank. Went to the local Ram dealer, and they are getting me in Monday to fix the bracket. It's technically not a "recall". FCA just extended the warranty to 12 years on the bracket. Attached is the letter from FCA.
  • LETTER..pdf
broncobill
Muskegon
I was just informed that the extended warranty is only good in Canada.
shmedley
Downers Grove IL
I just had the ones on my 14 Ram in December and I'm just west of Chicago. They didn't give me a hard time getting it in, just took them 4 days to do the couple hour job. I gave them the first day then I called the other 3 days and got "hoping to have it done this afternoon" I got no answers back otherwise. Not a fan of the service department there, that is not the only issue we've had with them. Had to get the regional involved one time.
My guess is they sat on it, doubt anyone would still be working there if a few hour job like that took them days.
Daw14
South Florida
If your dealer gave you that info it is probably time to find a more informed one , what else are they wrongly claiming ? This was not going to earn them much money so that could be a reason.
Either way I would find a different to do the job.
noraa73
