NY Andrew
When adjusting the speedometer, does that adjust the shift points?
I bought the truck with upgraded gear ratio, do I need to adjust that via the device or just leave gear ratio alone (not to sure the pros and cons of such)?
Does the Tazer write to the ECM OR PCM at all like a “flash” tune does to where the dealership COULD see and potential deny service? From what I read it seems like it just “unlocks” said features which I wouldn’t assume writes to the computer data files where it can be seen if undone, but then again if it changes speedometer not sure...
So I have a 2018 and it says you need the security bypass. Well if one was to buy the bypass from the sellers in this forum which taps in to OBD port, is the security bypass from Tazer still needed? If so, then it still has to go behind the radio and then what’s the point of the bypass harness for OBD sold here? Getting confused here. Wondering if I could just buy the OBD bypass and hook the Tazer right in to there without having to buy the security bypass from them that has to go behind the radio as well because I thought that was the whole reason for the OBD bypass to avoid having to go behind the radio? Or would the bypass module still have to be plugged in to OBD bypass? And if that’s the case then how would I keep the Tazer modules plugged in.....
