Terrible headlights
daberg
So I just bought a brand new 2012 Ram 1500 express last month in AZ and drove it up to AK. Really the only thing I've noticed that bugs me a lot is that the headlights are terrible and the high beams are even worse. Anyone else hear of this issue? I've skimmed the forums and haven't found too much on this. I want to put some HID's and maybe a whole new headlight assembly in but noticed that it isn't the easiest piece to get to. Any suggestions?
Thanks
Stangshcky12
Oshkosh, WI
5.9 Cummins
You'll here alot of people suggest jj lights
Retroshop is a vendor here specializing in HID projector headlights for dodge ram
Check them out
D
daberg
Cool, checked em out. looks good! there's a lot I want to do with the truck but the first thing I want is to change out the headlights and then the deck.
roadrnnr
Vermont
That is the biggest complaint. I put Silver Star Bulbs in mine and that made a slight differance. Then I put on the Mopar Fog light kit and that helped alot.
I am still planning on getting HID's though.
The actual assembly comes out pretty easily though. The instructions are on here somewhere.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
maybe its me, but with the fog/driving lights, I have alot of light on mine...now with them off, they do stink...but I drive all the time with mine on...and +1 for JJ's headlights :)
quietpeen
2021 TRX
Hellcat
it was a big complaint for me also. the light output is horrible. I got a set of JJ custom lights with 55W 5000k projectors and it is an amazing upgrade.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
did someone say headlights? :D
let me know if I can help! We can do a simple swap, or a full on awesome painted setup with projectors and the works!
carcandy
South Florida
2018 Big Horn cc 4x4
6.7 CTD
Is it possible to do a dual to quad swap? What all is needed?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
New lights is all you'll need.
I have some too!
I am in the process of getting my shopping site set up, but the quad lights are listed on here now.
TYC 2009+ Dodge Ram Quad Headlights
Use coupon code "10off" for 10% off of this item through the end of the month. :birgits_tiredcoffee
The lights are TYC lights - which are a great aftermarket replacement. They are typically used in body shops for crash replacements.
To use these on your truck, just unplug your current lights and plug the new ones in. :D
One thing to remember, in a typical quad setup, the lows stay on when the highs are turned on. When you swap from duals to quads, this doesn't happen. Just an FYI!
Ocelot
5.7 Non-Etorque
I have some too!
What does it have, an adapter plug to turn the single lamp socket into a double?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
the stock duals are H13, the quads have a plug that splits inside the light, but the end is a H13 connector. VERY easy swap.
1500ram12
5.9L Cummins
It is a very easy swap. I bought a set from jj a couple months ago. Look great work great. And fast shipping.
Sent From My DROID RAZR MAXX Using Tapatalk 2
corupt1
Westerville, OH
Got to agree that the headlight power has got to be a major drawback on the Rams. I drive mainly in the city, so it isn't a big deal, but when I get out in the country, I really notice it. I might be checking with JJ on a simple upgrade.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
:big_banana_Dance:
D
daberg
Well, looks like i'll be hittin up JJ then! thanks for the info everyone!
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
I just shot you back a quote! :D lots of goodies on that set!
ChloeBrooks
