Thanks!
dm12345
Los Angeles
Hemi 6.1
I'd like to blow up a UAS radio that i purchased from a dealership within the last year. It is over heating, but they will not warranty it on only overheating, "it needs to be faulty to be replaced" according to them. I'm in a remote location and there's no other dealership within driving range.
Does anyone have any suggestions as to how I can do this?
WY-Dave
Air Force
Cheyenne, WY
6.7 CTD
A "loose ground" usually plays havoc on solid state electronics. And sometimes, some arc'n and spark'n
retired
montana
hook it up to a 24V power supply and see what happens....I do not see how overheating is not a fault. wha is your driving range? Where I live anything within several hundred miles is considered driving range.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
If you get Ram cares involved they have helped others get the radio replaced under warranty. I would consider editing your last before involving them though.
D
dm12345
Los Angeles
Hemi 6.1
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Can any of you tell me what pins on the back of the radio are + / - power?
I can but you should really try ram cares first. It's a known issue and I've seen them get other's squared away. Especially if the screen is delaminating (wink wink)...
atc06jh
Middle Georgia
I would think over heating would be a warranty issue enough in itself. It could be worse though. You could overheat like these new Fords and burn it to the ground. Fords. Enough said.
retired
montana
ditto. Should be a safety recall if nothing else. Think of burning your finger on the touch screen way worse than a paper cut....
RamCares
n/a
n/a
Thanks for giving us a shout-out @SitKneelBend and @McBroom ! We appreciate it.
@dm12345 -- We're sorry to hear about the overheating concerns you're experiencing with your radio. If you'd like additional support while working alongside your dealer to get this fixed, please do not hesitate to send us a private message with more details! Thanks.
Courtney
Ram Cares
