The big 3
audio1der
Airdrie, Alberta
It never hurts, but you may as well wait and see if you get any dimming of the lights when the bass hits before you worry. If you need details, youtube has more details than we could ever type; it got me enough info to tackle it myself.
Just like we talked about with yer amp, electricity flows from - to + and the factory grounds are often of wimpy gauge so doing this allows the electrical system to function at its peak. Kinda like upgrading the intake over stock. Stock works, upgrade is better.
HLram
2012 and 2007
Hemi 5.7 in both
please enlighten me what is the "big 3"? lol My interior lights dim a slight bit when my sub hits.
pd298
SE Oklahoma
Basically you change some wires on your alternator and battery to 0 gauge power wire for more electrical current.
HLram
2012 and 2007
Hemi 5.7 in both
Got it, thanks. I am officially enlightened!
ramflava
Albuquerque, NM
6.7 Cummins Turbo Diesel
I haven't done the upgrade on the Alternator, but I have 1/0 gauge upgrade on the battery. I think if you do any kind of larger amplifier install, a minimum should be the battery upgrade.
S
scotts2012ram
Guest
Ive done it to both my trucks makes a big difference when u have 1000 rms watts pulling on those little wires. Before i did it you could fill the wires getting hot from the amps pulling so much power. Alot of people will tell you it doesn't help. If you have alot of power demand you need the big 3
UNBROKEN
2012 Ram R/T
I'll be doing it on mine along with a 250 amp alternator and XS power battery.
Beefing up your electrical system is never a bad thing.
