The new unhinged Hemi valve,lol
EriikK
Ann Arbor MI USA
Yeah I had a valve spring break too. I assumed it was a rare failure, is that not so? My intake valve didn't look nearly that bad and the piston was OK.
I did all the repair work myself but the machine shop bill was substantial -- 16 valve springs, 8 valves, plus machining. And cam and lifters and all the other stuff
I did while I was in there. If it now lasts a long time it was worth it... but it was a big job for sure.
W
The odd one does break.They're a mass produced product,that is subject to wear.
A valve spring will suffer metal fatigue ,especially if you run the engine hard,and the oil temps run in the higher ranges.
Years ago i stumbled across a test on valve springs,and there was a noticable differance in the life expectancy of a valve spring when the oil temps were at 190 compared to 220.A valve spring creates it's own internal heat when it's being worked,and the only thing cooling it is oil
