Thermometer location?
sydbarringer
Virginia
5.7L
It’s not that hot outside the truck. Where IS the temperature measured?
BOWERSFJ
Uniontown OH
You’re getting radiant heat from the asphalt, or your truck if it is a dark color .... Does it come down to the correct temp once you are moving ?
U&A
2016 3500 SRW
6.4 HEMI
The thermometer Should be on the underside your door mirror. Looks like a little plastics finger.
Sent while firmly grasping my redline lubed RAM [emoji231]
sydbarringer
sydbarringer
Virginia
5.7L
Eventually, yes? It’s parked on the street, driver’s side in the sun all day. THANKS.
