These things are big!
Txkenpo
Eustace TX
6.7 TD
Just got a new 2500 4x4 CC TD, yesterday while looking at the truck and test drove then crawled under, all over it occurred to me wow this stock truck is tall.. But I thought ah it’s fine surely it’s not over 6’8” tall so it will fit in the parking garage at work. ( Big Green building down town Dallas).
I was so excited to get into a HD from my Rebel with air suspension I didn’t actually measure the height till today. Got in the bed found the highest spot on the roof the center raised rail that’s stamped into the metal. Laid a 4” level across and had my son n law measure.. DOA! 6’ 8 3/4” just a tiny bit to tall... Well so much for covered parking at work, looks like surface lot from now on ):
ScLeCo
Earth
Supercharged 426
Air down you'll make it.
Reactions: U&A
Txkenpo
Txkenpo
Eustace TX
6.7 TD
How low you think would not cause weird tire ware but still clear?
Michael
In an undisclosed bunker
You just need to get a new job with better parking.
I know the voices in my head aren’t real, but man, do they ever come up with some great ideas
dhay13
hmmm. I measured mine more or less eyeballing and it looks to be about 6'6". Mine is a 2018 2500 6.4 Off-Road. I heard the Off-Road sit a little higher than other 2500's.
nighthawk87
Cummins
Just throw some sandbags in the back to level the rake out and it’ll fit. Also I bet you can just be careful and avoid the low parts.
NanaW
Washington State
Mine is 2015 Tradesman feels very tall will have to measure, but then again they are all tall to me I’m only 5’4” [emoji23]
Txkenpo
Txkenpo
Eustace TX
6.7 TD
Same truck and I thought the same thing but didn’t want to risk damaging my new truck. So I pulled out the 4’ level parked in flat level concrete and took measurements. I’m 1/2 “ too tall not willing to drop air pressure or lower the truck so will have to surface lot park.
There are pluses and negatives, can think about a lift, bigger, wider tires. But I’m subject to TX crazy weather ( hail)
1stindoor
NC
'23 2500 MegaCab
Should have opted for the mega cab...then you could have added a wider turning radius and sticking further out of your parking spot.
Txkenpo
Txkenpo
Eustace TX
6.7 TD
Well I cut a piece of pvc pipe 1/2” longer than height of my truck. Then walked my route to 9th floor. Turns out 6’ 8” is the Lowest point but that spot is not in my path so I’m good to go it’s closer to 7’ 1” in reality.
Purplert
Even though you know it will fit, the first time you try it I bet you'll duck your head a little. LOL
Jay
I’ve done this many times before lmao until I see another ram already in there and figure I’m good to go if he got in.
It’s gonna screw me up one day if the ram I spot has air suspension
1stindoor
NC
'23 2500 MegaCab
Now you know why they use those big antennas.
Reactions: U&A
dhay13
lol. i actually measured mine based off a local car wash that had a tube hanging saying 7' clearance and i stopped right under it and it looked like about6" of clearance
Come out of Lowes and this guy pulled behind me haha (yup it is an old 2500)
View media item 28079
WTF is wrong with people? With all the available spots, was that the only place he could think of parking? He has to be almost 5' into aisleway.
That why it's hard to have nice things [emoji3525]
