This just made my day!
MartyZ
Lake Orion, MI
2500 5.7l Hemi
Wow! You're gonna have to buy a 300k Club sticker for it soon. Congratulations man
Sportznut
2019 Laramie
Your day was brightened by Ozzy?
Haha [emoji23]
Congrats on 300k! Are you the original owner?
What repairs were needed?
chris1126
RAMINA
pa
congrats! make sure you post the 300k pic also
B
Big Daddy
Haha [emoji23]
You know it....Ozzy rules
I am the original owner, put all those miles on myself, here is my running list
- Rear end blew @ 35000 (Warranty)
- Rear pinion bearing broke - rebuilt rear end 295,000 (Warranty)
- Exhaust bolts (Warranty)
- Upper control arm and tie rods RT side
- Rt side wheel hub (Warranty)
- Rt side axle shaft (x 3) (Warranty)
- Cam broke at 160K (new cam, 8 lifters, 10 valves - Warranty)
- Rt side coil packs 140K
- Water Pump/fan clutch 140K and 275,000(Warranty)
- Trans shift solenoid 80K (Warranty)
- Pulley tensioner (Warranty)
- 3 sets of shocks
- alternator
- power steering pump
- 2 sets of lug nuts
- 6 sets of tires
- 5 sets of brake pads
- 2 sets of rotors
- 3 belts
- 11 sets of spark plugs
- 6 trans fluid changes
- 8 axle fluid changes
- 11 transfer case fluid changes
- Heater core
- AC Evap
- 2 heater solenoids
- radiator
- upper and lower radiator hoses
- 3 batteries
- antifreeze flush and change (x4)
- Rear window switch
EdGs
FL
- 3 sets of shocks
- alternator
- 6 sets of tires
- 2 sets of rotors
- 3 belts
- Heater core
- AC Evap
- radiator
- 3 batteries
Looks like you have run the course on your repairs, but the big stuff looks to have been covered.
Congrats on your milestone reached.
B
Big Daddy
When I bought it it came with a life time drive-train warranty and it has been good to me....
Burla
2010 Hemi Reg Cab 4x4
- 3 sets of shocks
- alternator
- 6 sets of tires
- 2 sets of rotors
- 3 belts
- Heater core
- AC Evap
- radiator
- 3 batteries
Warranty sure worked out for you! Good to see a member get so much value out of their truck. Ramily success story number 1.
JustaTradesman
Washington
5.7L
- 3 sets of shocks
- alternator
- 6 sets of tires
- 2 sets of rotors
- 3 belts
- Heater core
- AC Evap
- radiator
- 3 batteries
Wow ! That is a lot of repairs. I live here in the South and drive mine carefully. So what you have listed makes me wonder what I might be looking at in the future.
By the way, I just called the Mopar warranty department and they tried to tell me that you cannot change the fluid in the transmission. That was when I eventually ended the conversation.
B
Big Daddy
It's almost 12 years old with 300K miles. Seriously, tell me one other truck that would do better. And no diesels. BTW, the majority of that list is maintenance items.
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
Every 25,000. Coil packs on the older Hemi's do not like anything other the copper core plugs.
I replaced the coil packs on my 11 with coils from a 2015. Used iridium plugs, no issues for over 40k miles
Fyi, only.
erictomlin
Oxford, MA
Almost 300K miles and only 2 sets of rotors and 5 sets of pads??? Must be 99.99% highway miles. Good for you on getting all that work covered under warranty.
JS4024
Banned
NY
Yea... for the cam issue... should have been all the lifters, pushrods, cam, timing chain, timing gear and 3 free oil changes to clean all the metal out of the motor.... but aside from that you got your money’s worth from the lifetime warranty. Just be careful when they mention the “adjuster”. They will come and determine if your vehicle is worth less than the cost to fix and you are SOL!
B
Big Daddy
It is roughly 90% highway miles. I have never had an issue with getting work covered. I have the highest mile Hemi my dealer has seen so they want to keep it rolling just as much as I do.
B
Big Daddy
It will be coming, I know it.
KC5TGQ
Mississippi
5.7 Etorque
WOW on the list of repairs. Do you pull a lot of heavy loads? We have a couple GMC Sierra's in our fleet and one is at 330k and all its had is a water pump and a head gasket a couple batteries. The other is at 250k and just a starter and a few batteries. They do not pull much, just a tractor every now and then.
