Thoughts on air suspension? It is worth it? Will it break down?
BWL
Embrace the skeptisism
BC Canada
The dealer can adjust the parameters for each corner so they can fix the low corner for you.
Thanks i may try to get them to do that again next time it's in.
iam_canadian22
northern ontario
When i got my 16 the actually advised against air. Lots of issues up here in the winter time. Dont know if the new ones are any better or not.
Sent from my SM-G960W using Tapatalk
Accountant
CA
Laramie Hemi 5.7L
So far I haven’t heard of issues in the 5th gen compared to 4th.
Administrator
kballousr
McKinney, TX
I’m on my 6th Ram since 1997. The present and last one, have had the 4 corner suspension. I won’t own one without it now. I haul a 860lb motorcycle from time to time and pull a car hauler. The self leveling is awesome and stops the drag ass when pulling or moving weight. The lowering to load, ppl or stuff, makes life easy. I have the max care lifetime warranty so I have peace of mind. I’ve never had an issue and well worth the money.
Porkbutt
I think I read where some folks up north where it gets reallly cold have had some problems with air suspension in the winter, but not a lot.
bootucker10
6.7 l diesel
have a 2016 ram . it works beautifully pulling 16k horse trailer a so steady , horses like it . i've had just bladder systems in the past , but the firestone rubber starts to leak about 3 yrs , so had to pump to 100 psig before each trip . the current system is much better ..
Ray Hamilton
Bolingbrook IL
I have a 2014 RAM 1500 Laramie Limited with 40,000 miles on it. The only issue I have seen is in extremely cold temperatures sometimes I will get a message that it needs service and it goes into a safe suspension mode. As soon as the outside temperature raises a bit the message goes away and the suspension returns to normal operation. I like the system.
Cardhu
MB CAN
In northern Canada they don't order the air suspension. doesn't like the -30s or colder. I've heard of some anomalies making it but if your in a warmer area go for it.
Kukailimoku
Honolulu
I have a few trucks I am going to look at this afternoon and some have the air suspension. Just don't know if it is worth it, and how long it will last and the maintenance of it if it breaks. Would love some insight
Don't matter [if it breaks dwon a hundred times] if you get the Max Care Lifetime...
8732cuts
US
Mine stopped working the days the dealer dealt with Chrysler and no fix, so I sold our o n the spot for new truck. It would like to exit height on b the freeway
TerraNewf
NL, Canada
Mine was in the shop for 2 weeks with the same problem and no fix. Best they can do was the response, still lower on drivers front
Sportznut
2019 Laramie
2019 Laramie w/air ride. Only 4000 miles.
5th generation air ride is different than 4th generation...hopefully that indicates it is improved.
The 2019 Air Ride is noticeably better than my 2014 Big Horn without air but suprisingly when I upgraded the 2014 to Michelin LTX Defenders and Bilstein 5100's the ride quality was every bit as good as air ride. I did the tires about a month prior to the Bilsteins. I was very surprised how just the tires improved the ride.
I did find another great benefit of the air ride yesterday. It was nice to be able to lower it in an underground parking garage...just a little extra piece of mind.
Air ride might be more difficult to change tire size much. I will likely buy the extended warranty so I don't need to worry about repairs.
Good luck!
TerraNewf
NL, Canada
Good luck!
Good luck with it man, I hope it works forever for you. The air suspension is not very kind to me.
adrianp89
Tampa Bay, FL
Almost 5k, no issues here. Also the coldest it gets here is maybe low 30s once or twice a year.
TerraNewf
NL, Canada
If you get a chance can you measure the height from the top of your tires to the bottom of your front fenders. If the passenger and drivers side are the same height then it looks like they have corrected the problem in the 19's. My 17 sits lower on drivers side when in normal, off rd1, and off rd2 height.
Sportznut
2019 Laramie
Was you truck "tilted" like that when it was new? Did you have to measure it to notice it? Or could you notice it just by eyeballing it?
TerraNewf
NL, Canada
I measured it but know I can notice it as well. Hard to tell by just looking. I started a case with FCA and now my truck is back in the shop and I'm in a loaner again. The service manager said they have had trucks like mine but it will take time to find the problem. Lets see what they find out with the tech support of corporate.
Sportznut
2019 Laramie
Good luck !
Orca
