Throttle Body issue
sullivan
Houston, Texas
I recently noticed a bolt that holds the throttle body was not tightening up, which is letting air in between the throttle body and the intake manifold.
Any ideas? Im wondering if I can just tap the threads and use a slightly larger bolt.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Should be an insert into the plastic manifold housing I believe.
sullivan
sullivan
Houston, Texas
I am going to go pull everything off and inspect this. Hopefully it is just the insert I need to replace
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
I was looking to see if I had a pic of mine to be sure and its just the underside pic not the front port side.
05singlecabHEMI
Lilburn,GA
had this pic laying around. it does look like it has clips. hope this helps
