Tie Rod Ends.
RoadKing
Ga
2022 Bighorn
HEMI 5.7
Hey i noticed one of my tie rod ends rubber boot is cracked.
A lift guy that did the lift for the previous owner said it was probably fine for awhile still.
i figure just replace both OEM tie rods.
But I did notice online there are some companies that boast their tire rods are better then OEM.
So my question is being that the truck has big wheels and tires on it and maybe I should get a more robust tie rod end?
Or it does not really matter?
thanks.
Priley
North Augusta sc
Hemi 5.7 etourqe
What’s the wheel and tire set up? And my opinion would be to get more robust ones since you’ve had this problem with the OEM tire rods if I was you I’d take my time and do some research to find the best one you can it’s better to be safe then sorry
