timber grove bags installed
cody mummert
Pa
so i installed my bags last week and took the travel trailer on a trip i end up with 45 lbs in the bags and still had some purposing. i also have the e-qualizer hitch do i need to move my bars up to get a bit more tongue weight ?
OC455
Central NY
If it feels like you have some porpoising and it feels like the trailer is "hitching" (don't know a good term for it) back and forth, you probably need a bit more on the WD hitch.
cody mummert
cody mummert
Pa
i have the the bars about as low as they will go in the brackets. so i guess im my theroy if i raise the bar/brackets via the bolts on the tongue of the trailer it should act like a wheel barrow and put more weight on the ball ? correct ?
OC455
Central NY
You're going to be transferring more weight to the truck itself. More towards the front overall. What type of WD hitch do you have? Okay, I looked it up, you have to adjust your brackets on the trailer frame to get the brackets higher then to get more WD to the front.
There's no adjustment on the hitch head itself on your WD hitch then.
OC455
Central NY
How much adjustment do you have with the trailer frame brackets?
cody mummert
cody mummert
Pa
i will have to look when i get home but i think the bottom of the bracket is even with the bottom of the trailer frame
cody mummert
cody mummert
Pa
sorry i should have made sure of all the details before posting
OC455
Central NY
Nope you are good....I need to re-read what people write...I read through things to fast sometimes.
OC455
Central NY
I would move your brackets up until and test drive it to where there is little to no porpoising and hitching. Then find a CAT scale to see where you are at.
VernDiesel
Dayton OH
ED
Post your unloaded truck numbers and your loaded truck with wet trailer & WD applied numbers. Without it your guesstimating trying to get in the ballpark. With numbers you can see what needs to be adjusted to more quickly & concretely put you in the zone.
OC455
Central NY
How did it go?
