Tipm issue
Goldntoken83
Kansas
03 Dodge ram 1500 4.7 SLT quad cab having trouble with power distribution box and FCM. No wipers, no headlight control, no blinkers, no horn and lights no longer flash when locked. Headlights come on and stay on. I've tried two other used distribution boxes and I've tried 4 different used forward control modules and still have the same issue. What am I missing I'm loosing my mind.
Burla
2010 Hemi Reg Cab 4x4
You try a new TIPM? You can fix them if you can soder and know how to use volt meter.
Jeepwalker
WI
2012 Reg Cab, 4x4
You didn't mention it, but have you had your tk's battery load-tested? (free service at most parts stores, or buy cheap HF load tester HERE). And verify all battery connections AND grounds are good. And batt connections to the fusebox.
Sounds hard to believe, but a weak battery will wreak all kinds of havoc and odd behavior. That would be my first thing to rule out. Maybe you already did those things, but if not, rule them out for sure.
