eljefe
35x12.50x18 Toyo AT2. What air pressure do you run that keeps the darn warning light off? Can I adjust that with my AlfaOBD?
Sent from my SM-A716V using Tapatalk
I added air to roughly these numbers and in the rain I was sliding all over the place. Now I'm at 35 front and 33 rear and TPMS won't shut off.42F/40R .... No TPMS .... Wore perfect, and rode great
Put them both at 35 what does the sticker inside your drivers door say?I added air to roughly these numbers and in the rain I was sliding all over the place. Now I'm at 35 front and 33 rear and TPMS won't shut off.
You can adjust warning pressure or convert to tpis with AlfaOBD.35x12.50x18 Toyo AT2. What air pressure do you run that keeps the darn warning light off? Can I adjust that with my AlfaOBD?
I don't have the harness but have no issues making changes with my alphaobd. Ill do a search. @bigdaddyshouse always has the answers. LolalphaOBD will let you fix tps. do you have the bypass harness from @Mpgrimm2 ? @big daddys house has what you need for alphaODB help as well
Correct only need for 18 and up.I thought it was 2018 and newer you need bypass for
CorrectMine is a 2017. If I get my 4 digit code from the dealer won’t that be enough?
