Tire pressures
DRam2019
Connecticut
So I was looking at the door sticker for tire pressures.... 60 psi front, 65 psi rear. This is on a 2019 2500 6.4
F250 I just traded in on it was like 65 front, 70 or 75 rear if memory serves. Tire sizes same on both. Thoughts.
1500ram12
5.9L Cummins
Hmm it's possible they lowered it. It's been 75-80 in the front and 80 in the rear
2018 2500 6.4L Hemi Tradesman
dexter
Banned
Mine is 60/80
Do you have load range E or D tires?
Maximum Load: 2,623 lbs.
Max. Inflation Pressure: 65 psi
Load Range: D
Maximum Load: 3,042 lbs.
Max. Inflation Pressure: 80 psi
Load Range: E
dexter
Banned
Load range E
Very strange.
Is it possible you don't have a HD truck? I don't know if there is even one that isn't HD.
If the sidewalls say 80psi max you don't get full load ability of the tires at lower psi.
As a matter of fact under filling when at max payload could cause a blowout - cause; excessive flexing of sidewalls and heat
D
DRam2019
Connecticut
Very strange.
If the sidewalls say 80psi max you don't get full load ability of the tires.
It’s a 2019 2500 tradesman. 10,000 gv so it’s a HD
JoeCo
NY
There is a Ram customer care person here someplace.
I'd ask them. Let us know what you find out.
It's worth a shot I guess, but I'm going to predict they would respond with a "we recommend you make an appointment with your dealer" generic response.
