tire size change
Paulpin
new jersey
2023 echodiesel new tires placed dealer changed from 275/55/20 652 rev per mile to 285/55/20 643 rev per mile asked them to recalibrate for the differenr tire size
should i find another dealer
i have 2 2023 echodiesels both with 22,000 miles one is losing coolant
no dye was placed nor did they check the exhaust for coolant
if the dealers so called certified techs are this bad were to go ??
MADDOG
Living in a Firepit
Most dealers can't, or won't, touch the Body Control Module to re-calibrate the speedo for tire size changes. It's a software/cost issue and the dealers are not willing to pay for the limited license from Stellantis last time I checked.
Some tire shops can re-calibrate and it may be worth your while to give some local shops a call and ask.
Lastly, you can license AlfaOBD, get an interface cable and a OBDII dongle and calibrate it yourself. AlfaOBD has a large number of other functional change options you can select if you so choose.
P
Paulpin
new jersey
thanks for the reply GROK gave the same answer what's troubling is they did not say they could not do it but it is not possible on this truck GROK also said it not only affects speed reading but is tied into all the safety features traction control auto braking cruse control my wife drives this ram so I'm wondering how important this is GROK also offered to print out the instructions to hand to the dealer tech since I'm still under warranty didn't want to do a software change
Dredger
SE Ohio
The difference seems to be negligible; I wouldn't worry about it. :confused:
MADDOG
Living in a Firepit
@Dredger is corrent. The MPH reading difference will be minimal.
MADDOG
Living in a Firepit
This is contrary to my experience with the issue.
