Tire upgrade question
Dickencider90
Baltimore
I have a 2016 ram 1500 express crew cab 4wd it has the 17 inch rims on it. I would like to know whats the biggest size tire I could put on it without having to cut and I don’t wanna have any rubbing. It is stock height and already have my eyes set on KO2’s
Dickencider90
Dickencider90
Baltimore
Don’t know just know they’re stock rims was supposed to have 20s but dealership has 17s on it
pacofortacos
I personally do not like how 285/70/17's handled on bends on dry pavement on my stock 17 x 7" wide stock wheels.
With 17X8" wheels they are fine.
Some don't mind the handling but it just felt squirrely if you hit a bump or the brakes when going around a bend - and they were E-load Michelin Defenders, not a low line tire by any stretch.
If you don't mind that I think some have gone as high as 305/70/17 with just a level.
Others have gone to a 75 aspect ratio vs. the 70 and those would probably be ok on a 17x7" rim.
Note, if you look on tirerack they do not rec. using a 285/70/17 on a 7" wide rim.
