Tires
Misfit
I have a 2013 ram 1500 4wd. Stock tires are 275/60r20, will lt275/65r20 tires fit with no mods
17CrewCab1500
You understand the 65 is a percent of the 275 correct? So 5% total difference but only 2.5% in height.
Basically you're going from a 33" to 34" tire. Not much of a difference.
M
Misfit
I was just wondering if it was going to rub anywhere when the wheels turn, didn't look like it would even though it's close
M
Misfit
Just wondered if it was going to rub anywhere when turning hard, looks like it would be close. Hadn't found any info about it.
kooler1
Agreed. You should be good. Believe even a 35 would clear. Depending on width
