Tonneau cover multifunction tailgate
1011555
CA
I'm looking at a 2020 Dodge ram rebel with a 5,7 box with multifunction tailgate. Has no rambox
What are my options as far as tonneau covers. Just spoke to backflip rep and he said they don't have anything that fits a box with multifunction tailgate. I'm looking for something that can't be penatrated and can store in vertical position if I need to put my motorcycle in the bed
Sent from my SM-G975W using Tapatalk
CA
Did a little digging and found out that if the oem brackets are replaced with brackets from rightonbracket.com most if not all covers will fit.
shaginwagon
Dallas
I have had Truxedo X15 on prior trucks and they are saying it WILL NOT work with Multi-function tailgate. Can someone let me know what soft roll-up bed cover they have with a multi function tailgate.
BNeal
Celina, TX
2021 Limited
That is correct. Replace those brackets, and you're good to go.
Bill A
Southern Oregon
I have the same box and tailgate and went with the Xtang Solid Fold. Very happy with it. For open position the two rear panels fold on top of front panel and strap down so you still have 1/3 of bed covered. To load a motorcycle you would need to remove the cover which involves undoing two clamps (by hand and lifting the cover off). Takes less than a minute. Cover is very light but very strong and very affordable. One advantage of the folding covers when compared to the solid fiberglass covers such as Leer is the tailgate can be lowered or swung open without lifting the cover.
BNeal
Celina, TX
2021 Limited
Again, with the brackets, it will fit. I have the BakFlip and it does exactly what you describe.
mikeru
Super Moderator
Moderator Supporting Member
Eastern WA
2020 Limited
Hemi 5.7L non-Etorque
I think you missed where he said he does not have the rambox option. Rambox beds with the MFT do not have the extra bracing that the non-rambox beds have. So for the rambox beds, pretty much any bed cover that works for non-MFT beds will work for rambox beds with the MFT.
TimboRam77
Truxedo Sentry ct and is a cut above the bak2 revolver. Fits split tailgate but you have to quick disconnect the entire thing for a motorcycle. Not hard to disconnect but bulky to move once disconnected. Almost water tight. Beautiful and not easly penetrated. Mounting was a little tough with rambox but once fitted looks sharp.
dieseldave
Little Suamico
Tyger T1. I just installed mine. Great fit and nice quality and great price .$189.00.
BNeal
Celina, TX
2021 Limited
I knew he didn't have Ram boxes, that's why I mentioned you have to switch out the brackets. I was simply showing him how it works with MFT and how it folds all the way up to accommodate the motorcycle.
mikeru
Super Moderator
Eastern WA
2020 Limited
I'm confused about which brackets you're referring to. There are no brackets on the rambox beds. Or are you talking about the utility rails?
BNeal
Celina, TX
2021 Limited
Sorry if I confused the conversation. There are no brackets on trucks with Ramboxes. What I meant to say was if you have a truck with a MFT without Ramboxes, then you will have factory brackets that will prevent you from installing a BakFlip, so you'll have to replace the factory brackets with 3rd-party brackets so you can do the installation.
shaginwagon
Dallas
Tyger website says the T1 is not compatible with MFT. Can you confirm you have MFT and there was no issue with install or leaks?
thanks
dieseldave
Little Suamico
thanks
The Tyger T 1 fits perfect on my 2021 Ram 1500 CC 6.4 bed with the MFT. The Tyger T 1 sits on top of the rails, not inside the rails so the added support brackets on the front of the bed do not interfere with the cover.
GChandler
SC
Hey BNeal, that looks sharp! I just got my ‘21 Limited with RamBox and split tailgate. Which Bakflip did you install? Mx4 or F1? I see your upper brake light and they described that as a benefit with F1. Any major leaking problems? One nice thing is I got the electronic rear view mirror so even with the cover up behind the back window I’ll be able to use the rearview “ mirror”! Thx!
Southlake
USA
5.7 etorque
Anyone know why they install such large brackets. Will the bed be ok of these are just removed. What.os the purpose of these? Thanks
mikeru
Super Moderator
Eastern WA
2020 Limited
You don't want to just remove them. They are there to help support the bed sides when you open the MFT tailgate in the non-traditional way. Some people have replaced them with these so they can have a larger selection of bed covers...
cdub5
