Top end replacement kit
Finney83
I'm looking to redo the top end of my 2012 Ram 1500 5.7(please forgive if I've used the wrong term). I'm looking for a kit(s) that has the following (assuming it's actually made). I'm not looking to modify or sup up. Better than OEM is good, not looking for performance. Just like factory new or slightly better. Open to advice on options, parts, ect.
Valves
Timing chain
Water pump
Lifters
Cam shaft
Seals/gaskets
Valves
Timing chain
Water pump
Lifters
Cam shaft
Seals/gaskets
Hit up Benny he'll probably put a kit together for you
F
Finney83
Benny? I search Benny and a number of different results came back. Could you be more specific?
F
Finney83
That's probably part of my issue. My phone isn't showing an active link.
AllMoparParts.com
- Benny
Supporting Member Supporting Vendor
All
All
Valves
Timing chain
Water pump
Lifters
Cam shaft
Seals/gaskets
Hi,
Please message me your Email address and I will send you a quote on new OE parts.
Thanks,
- Benny
