I've had my Edge 2800 stall in since August 2011,
Hands down favorite mod (other than a Supercharger)
It actually flashes to 3000 from idle launching it at the track on 4 DR's, (intake, exhaust and tune)
I dropped 3-4 tenths off my 60 foot times instantly and it's like there is no torque management
because you are almost instantly into the powerband....no bogging off the line.
My 10' RCSB 4x4 does 5 seconds flat 0-60 on heavy street tires with ****** 3.55 gears
(305/50R20 Terra Grappler's on stock 20's)
I can light up the rear tires at will with just half throttle,
So if I want to race I need to use AWD (4-Auto) for traction or it will just sit and spin.
Since adding a Ripp Supercharger it now hits 3300 at launch and does 4 seconds 0-60 in AWD.
I'll be swapping the Edge out soon for a 3000 stall ATS Triple Lok torque monster in September,
along with my custom built transmission from L&M Customs.
as far as the rumors of Edge looking like Stock, its' close but not quite
Stock verter has part number stamp engraved and is not painted,
Edge comes painted silver
Stock
Edge
on the bottom is the real difference, Stock has welded tabs for mounting bolts
Edge has what appears to be a welded ring with 4 tapped holes for mounting to the flexplate
a Street Edge 2800 for $525 is awesome for Racing, not so much for towing.
If you tow on a regular basis, Go with a Triple Disc Billet unit from Circle D
and have them build your stall speed to around 2600 tops.
Only catch is the $$$, you're looking at $1k for a good tow rated Circle D
For those looking to DIY install, here's a copy/paste from the factory service manual:
Here are the procedures for trans removal:
1. Disconnect the negative battery cable.
2. Raise and support the vehicle
3. Remove any necessary skid plates
4. Mark propeller shaft and axle companion flanges for assembly alignment.
5. Remove the rear propeller shaft
6. Remove the front propeller shaft, if necessary.
7. Remove the engine (1) to transmission (3) structural dust cover (2).
8. Remove the exhaust support bracket from the rear of the transmission.
9. Disconnect and lower or remove any necessary exhaust components.
10. Remove the starter motor.
11. Rotate crankshaft in clockwise direction until converter bolts are accessible. Then remove bolts one at a time. Rotate crankshaft with socket wrench on dampener bolt.
12. Disengage the output speed sensor connector from the output speed sensor
13. Disengage the input speed sensor connector from the input speed sensor
14. Disengage the transmission solenoid/TRS assembly connector from the transmission solenoid/TRS assembly
15. Disengage the line pressure sensor connector from the line pressure sensor
16. Disconnect gearshift cable (1) from transmission manual valve lever
17. Disconnect the transmission vent hose from the transmission.
18. Support rear of engine with safety stand or jack.
19. Raise transmission slightly with service jack to relieve load on crossmember and supports.
20. Remove bolts securing rear support and cushion to transmission and crossmember.
21. Remove transfer case, if necessary.
22. Disconnect transmission fluid cooler lines at transmission fittings and clips.
NOTE: When disconnecting the transmission oil cooler lines, it is necessary to replace the line clip that is located on the oil pan stud. The retention force of the clip is severely degraded upon removal.
23. Remove all remaining converter housing bolts.
24. Carefully work transmission and torque converter assembly rearward off engine block dowels.
25. Hold torque converter in place during transmission removal.
26. Lower transmission (2) and remove assembly from under the vehicle.
27. To remove torque converter, carefully slide torque converter out of the transmission
Here are the steps for tc removal:
1. Remove transmission and torque converter from vehicle.
2. Place a suitable drain pan under the converter housing end of the transmission.
CAUTION: Verify that transmission is secure on the lifting device or work surface, the center of gravity of the transmission will shift when the torque converter is removed creating an unstable condition. The torque converter is a heavy unit. Use caution when separating the torque converter from the transmission.
3. Pull the torque converter forward until the center hub clears the oil pump seal.
4. Separate the torque converter from the transmission.
