Totally screwed up
I decided to put axiom LEDs in my projectors...bad idea....I had to cut a hole in the weather cover to do a rubber extension cap. Against my better judgement I went for it cut the hole put some silicone and reinstalled itbut it doesn't fit so now I have a hole. Does anyone know where to get replacement cover so I don't have to buy a whole new assembly I'm a *******
Sent from my Z981 using Tapatalk
Curlyp
OH
I think you may have posted your thread in the wrong generation. You have a 14' truck right? It would be a 4th gen! [emoji16] one of the mods should be able to move it for you.
joelindsey1981
Im a Foo
I decided to put LEDs in my projectors...bad idea.. I had to cut a hole in the weather cover to put a rubber extension cap....should have stopped there...but against my better judgement I went on installed everything and the put them back on...and of course they didn't fit.so now I have a hole. Does anyone know where to get parts for project headlights preferably the weather cover..I'm a ******* please help me
MarshRam
2014 SLT 4x4, 2012 ST
This post looks familiar or I'm having dejavu??? Take some pics. I put LED in my aftermarket lights and my end cap did not fit. Had to do some retrofitting. This stuff might help you out.
Dirtydodge14
Yeah. Retrofitsource.com has entire kits and individual parts for the project. They are a highly recommended company on the forum. I'm going to buy their kit once I gather the loot for it. Not necessarily cheap but they make hid kits specifically with ram in mind along with any resistor/capacitors (excuse my non informed electrical lingo) that work without flicker and such.
OnSale
5th Gen Crew
Philadelphia, Pa
What you can do is go buy a tube of plastic weld. Cut out a piece of cardboard the EXACT size of the hole in your projectors dust cap. Then push the cardboard into the hole so its sorta snug in there. If there are some open spots, it's ok. Just make sure the cardboard won't fall out. The use the plasticweld and cover the cardboard you put into the hole and spread the plasticweld to make a seal from one side of the hole, over the cardboard and to the other side of the hole, making sure to put the plastic weld about a 1/4 inch past the hole to make a strong bond to the dust cap.
Let it dry. You can then either cut out the cardboard piece or just leave it. Either way this will 100% reseal the hole.
You can get plastic weld at pepboys or autozone for under $10.
• 2012 Ram 1500 RCSB Hemi • 22" SRT-10 Wheels Plastidipped Black w/ Bridgestone Tires • Smoked Taillights • Custom Quad Headlights • Opt-7 FluxBeam-X 6000k LED Lows • MicTuning 6000k LED Fogs • K&N 63 Series CAI • Flowmasters Muffler • Line-X Bed • OEM Black Badges All Around • 20% Tint All Around • Lund Tri-Fold Tonneau + plenty more coming soon...
frenzy_6900
